Activity › Forums › Lighting Design › How do I light Interior Interviews with mixed lighting?
  • How do I light Interior Interviews with mixed lighting?
    Posted by Patrick Corr on January 17, 2019 at 4:44 pm
    I’m having some trouble white balancing when there’s a mixture of natural light and artificial fluorescent/tungsten light in same scene and I’m wondering if I could ask for your help?
    I shot an interview in a laboratory during middle of the day. However, the light from outside was getting dark so it didn’t light the room very well. As a result, I had to switch on the overhead fluorescent lights – they cast a yellow/green tone on my subject.
    I had an Ikan LED set to 100 percent brightness so I could light my subject’s face for interview. I set the Ikan whitebalance to 4300 so it would match the interior lighting.
    I set the camera white balance to daylight, otherwise the light from outside would have looked incredibly blue!
    When I had to edit the interview, I saw that the outside light was correctly white balanced, but the room and the subject’s white lab coat and face were very yellow/green. I had to use a lot of secondary correction tools and masks in post to fix everything.
    I was wondering, for interviews, should I keep my white balance on camera at daylight if you can see windows in shot?
    If I have the camera white balance at daylight, which makes the yellow interior even more yellow, should I have my LED at 5500k to get accurate skin tone? I was with a director during this shoot and he asked me to set the LED to 4300 but that made the Colour Correction a nightmare in post!
    Difficult Scene with mixture of windows/ natural light and artificial yellow light
    I don’t have this issue when I’m dealing with only natural light. In this scenario, everything, including my Ikan LED wb was set to 5500k and I found it very easy!
    Easy Scene with no artificial light, only natural light and LED set to daylight
    Note: I’m using Sony FS7 so I can only use wb presets in camera like 3600k, 4300k and 5500kelvin
    Thanks everyone, I’m sure I sound very amateur but I really appreciate any advice!
    Patrick Corr replied 7 years, 8 months ago 3 Members · 10 Replies
  • 10 Replies
  • John Sharaf
    January 17, 2019 at 5:43 pm
    Hi Patrick,
    As you’ve proved already to yourself, keeping all the source color temperatures is the key to avoiding a mss match between the foreground and the background
    One simple solution is to use the same tubes that are in the practical overhead lights in a 4′ kino flo instrument and then wb on that. We often refer to this as “poisoning” the light.
    Alternatively but never as foolproof is to add green gel to your key light in order to match the “ambience” created by the overhead fluorescents, but it’s still pretty much trial and error in determining whether 1/4, 1/2 or full Plus Green gel is the appropriate amount.
    If this is something you do all the time, investing in a 4′ Kino 4Bank is a really good solution
    JMHO
    JS
  • Todd Terry
    January 17, 2019 at 5:44 pm
    You don’t sound amateur, at least you are asking the right questions.
    You’ll want to go with your predominant source… or the one you can’t change… as your guide for color temperature. Since you can’t change the color of daylight (and gelling that many windows would be a nightmare), you should think of something in the 5600°K neighborhood as your “target.” Ergo, try to match the lighting on your subject with more or less the same temperature. I would have cooled down the LED fixtures (raised the temp) to match that. As you said, you found color grading easy when you did that, and that was the right choice. The ceiling flos are always going to be an issue. Of course it depends on what tubes are in there… in the “olden days” you could bet on the flo tubes to be quite cool… which would be a good thing, since their temps would be more on the daylight end of things. These days though you’ll just as often find very warm tubes (such as here in my office right now), and that’s going to prove more problematic. If I am on a location with flos, I will generally turn them all off and light the room myself. Cheap consumer flo tubes are always going to have a bit of that sickly greenish/yellow spike in their spectrums, no matter what color temp the tubes claim to be.
    I believe you actually posted the same picture twice in your samples there (I certainly can’t see any difference, and they have the same file name)… but whichever that one was, you did a fine job with it, I don’t see any cringe-worthy issues at all… the grading actually looks pretty good… the focus, on the other hand… hmmm… but maybe that was just a test shot.
    T2
    __________________________________
    Todd Terry
    Creative Director
    Fantastic Plastic Entertainment, Inc.
    fantasticplastic.com
  • Patrick Corr
    January 17, 2019 at 5:50 pm
    Sorry, this was the second image where I didn’t have any issues! I can’t seem to edit my post above:
    Thank you so much!
  • Patrick Corr
    January 17, 2019 at 5:57 pm
    Todd thank you very much! I do need to invest in more powerful LED setup, I just have an Ikan Rayden (3200K-5600K) LED and it’s quite small so probably only for fill light rather than a key!
  • Todd Terry
    January 17, 2019 at 6:00 pm
    I know it was probably a grading nightmare, but I actually greatly prefer the lighting on the guy in the lab.. it just looks much more natural.
    The guy in the workshop there isn’t bad, certainly not temperature wise, but it’s not as interesting as the other, by a long shot. A back/rim/hair/side light on him would have been helpful, to help pop him out of that bland particle-board background. Also, your key on him is a bit backwards from what most people would consider “normal” portrait style lighting… you’d more often see the key on the other side of the camera (more lighting the opposite side of his face), but that’s not a hard and fast rule. If you want him to appear illuminated from some natural source (say, we’re assuming that workshop has a window to the guy’s left), then that’s the appropriate side… but at first blush it’s just not aesthetically the best look for him in an interview-type setup (as opposed to some narrative work, a scene from a movie or whatever)… where normally your subject would face toward the side the key is on rather than away from it.
    T2
    Todd Terry
    Creative Director
  • Patrick Corr
    January 17, 2019 at 6:04 pm
    I totally agree! Normally I would have lit the subject from his hard left, but I was in a very cramped kitchen in New Mexico and there wasn’t ample space to do so, while also getting in those nice reds in the background. I think I was trying to get nice depth of field but not shoot against the window that was in the top right corner as it was blown out!
    I haven’t been doing this for long (maybe only a year doing proper equipment for corporate shoots) so I do struggle when I have to make snap decisions under difficult time constraints when I don’t have time to really plan out locations!
  • Patrick Corr
    January 17, 2019 at 6:11 pm
    Thank you John – that sounds complicated! I’m still learning ☺
    Thanks for your reply – do you mean matching the 4′ Kino 4Bank lights with the same temperature as the overhead fluorescents?
    I should invest in green gel! I have red and blue gel for a set of tungsten redheads, but I switched to LEDs as the redheads were a nightmare for me! They were incredibly red and only worked well for me when there was no ambient light source from sunlight. I only sometimes use them to light backgrounds but only in some shoots where there’s lots of time for me to set up before I’m shooting!
  • Todd Terry
    January 17, 2019 at 6:17 pm
    [Patrick Corr] “I do struggle when I have to make snap decisions under difficult time constraints when I don’t have time to really plan out locations”
    Well, planning of course is a great thing, it’s a necessity not a luxury and you almost can’t do too much of it.
    But… looking back over the last almost three decades that I’ve been doing this, I would say some of my best looking scenes where those where I was thrown a curve ball and had to come up with something I wasn’t expecting… those “happy accidents” as Bob Ross would say.
    You seem to have a handle on it, you’ll get there.
    T2
    Todd Terry
    Creative Director
  • Todd Terry
    January 17, 2019 at 6:19 pm
    Your reel is very very pretty, BTW.
    Yeah, I stalk newbies here, so I know who I’m dealing with.
    T2
    Todd Terry
    Creative Director
  • Patrick Corr
    January 17, 2019 at 6:21 pm
    Thank you Todd, and I love Bob Ross! Have a great day/evening/night!
    It’s evening here in Ireland now! Signing off now!
