Activity Forums VEGAS Pro How do I keep track of chapters
  • How do I keep track of chapters
    Posted by Doyal Gudgel on May 24, 2011 at 5:46 am
    What I plan to do is string together a lot of chapters and doing some editing on them in the process. I want to lock an ID chapter number to the start and end of the chapter. Can I lock this position to the start and end so it cant be lost or separated? This would be good in case I mess up a chapter on down the line somewhere in which case I could just delete the damaged chapter and move the original chapter into the timeline again. But I need to lock the ID to the beginning and end if I can. Unless there is a better way of doing it of which there probably is. I’d appreciate some advice on this.
    Hope to see you
    https://seniorobserver.blogspot.com, https://billswar2.blogspot.com
    Doyal Gudgel replied 15 years, 3 months ago 1 Member · 1 Reply
