Activity Forums Avid Media Composer How do i keep the best quality – Digi Beta – Avid – AE – Avid
  • How do i keep the best quality – Digi Beta – Avid – AE – Avid
    Posted by Chris Huggett on August 16, 2005 at 9:17 am
    Hey guys
    Im a gfx designer in a TV Station. The producers cut their promos at 1:1 on a Unity drive. I currently export out at QT Animation 100%, import in AE with project settings of 16bit, then export back out to QT Animation 100%, and import into Avid at 3:1.
    First off, the vision has been captured uncompressed, at 10 bit (i think). Is QT a 10 bit medium?
    Secondly, Using AE at 16 bit, does this affect the imported files?
    Thirdly, is this an acceptable work flow, and can it be enhanced (we cant use Automatic Duck because i dont have access to the unity drive)?
    Will Microcosm help my quality if the above doesn’t?
    Thanks for any help
    Chris
    https://www.acclaim.tv
    Todd Beabout replied 21 years, 1 month ago 2 Members · 1 Reply
  • Todd Beabout
    August 16, 2005 at 11:02 pm
    That workflow sounds pretty standard, man. Do you HAVE to bring your final graphics into Avid at 3:1 though? If you are experiencing quality loss, that’s probably where it is happening.
    Yes QT is 10-bit, but I think that is more based on codec…
    Importing into AE @ 16-bit should be fine, as far as I know.
    And I don’t know what microcosm is… Hope this helps.
    -Todd Beabout
    Vazda Studios
