How do I invert a mask?
Posted by Darren Campbell on July 31, 2010 at 3:35 amIn the pan/crop window I want to invert a mask, how do I do it?
Roger Bansemer replied 16 years, 1 month ago 3 Members · 4 Replies -
Graham Bernard
July 31, 2010 at 6:09 amInvert Mask Shape: Click on “Position” in the p/c Timeline then Rotate or Flip
. . or . . .
Invert Mask Effect: Select “Mask” in the p/c Timeline then Change the “Mode” from Positive to Negative
Grazie
Roger Bansemer
August 1, 2010 at 11:36 amHow is the entire mask moved to a different position altogether? The normal edit tool just moves the entire screen around.
Graham Bernard
August 1, 2010 at 6:12 pmRoger, you need to click on at least one of the Anchors and then right click to select the PATH then you can move the whole Mask.
These points can be tedious to learn how to manipulate, but once you have squeezed out the way to do it, there then follows an understanding of the logic.
Grazie
Roger Bansemer
August 1, 2010 at 7:15 pmThanks for that. I don’t think I ever would have figured that one out.
