Activity › Forums › Adobe Premiere Pro › How do I import export presets and effects presets from CS6 Mac to CC?
  • How do I import export presets and effects presets from CS6 Mac to CC?
    Posted by Peter Corbett on July 1, 2013 at 12:04 am
    I’ve searched the web but can’t find and answer to this. I just want to import my export and effect settings which I’ve built up over the past year to CC. Any clues?
    Peter Corbett
    Powerhouse Productions
    http://www.php.com.au
    Jim Hoyle replied 11 years, 8 months ago 3 Members · 3 Replies
  • Chris Borjis
    July 1, 2013 at 5:12 pm
    Are you talking about Media encoder exports?
    open AME CS6, just above the presets on the right pane there are a few buttons.
    one of them is export…hit that and it will prompt you where to export
    them to. all of them will end up in that folder you pick.
    Open AME CC, then pick the import button and select all.
    I did notice any presets having to do with MPEG2 codec would not import into CC version of AME,
    because that part has changed a bit, so those you would need to recreate.
    I just did screen shots of them.
  • Peter Corbett
    July 1, 2013 at 10:33 pm
    Thanks Chris. I’ll give that a go. They should then appear in Premiere CC.
    Peter Corbett
  • Jim Hoyle
    January 29, 2015 at 2:13 pm
    I am trying to copy settings from another hard drive on Mac. I was able to successfully copy all other relevant settings but I could not find anywhere this information:
    Where are the files for Premiere CC & AME CC Export Settings (Presets)? I know that AME’s Import and Export work (and you can even do multiple files at once), but I want to copy the settings files without having to do the export.
    I could not find the files by doing a text search for all files in my hard drive, so the settings seem to be in binary format. But perhaps they still can be copied?
