Activity › Forums › Apple Final Cut Pro Legacy › How do I highlight a moving object?
  • How do I highlight a moving object?
    Posted by James Thomas on June 18, 2014 at 5:29 pm
    I am putting together surveillence videos and I need to place an oval or highlighted shape over the object being viewed. I see this in many videos, but cannot figure out how to do it in FCP 7.
    The circle under shapes is solid color only. I can lower the opacity, but when I put motion to it the black shaded area around the shape moves with it.
    I have tried creating a circle in photoshop and putting it on my clip, but had no luck.
    James Thomas replied 12 years, 3 months ago 2 Members · 2 Replies
  • Mark Suszko
    June 18, 2014 at 6:21 pm
    Change the blending mode of the shape, MODIFY>COMPOSITE MODE, then adjust opacity.
  • James Thomas
    June 18, 2014 at 7:41 pm
    Thank you. That will work. I also found out I can use slug with a mask shape filter.
