Activity › Forums › Apple Final Cut Pro Legacy › How do I have different aspect ratios in anamorphic project
Posted by Beverley Callow on April 23, 2009 at 7:12 amI have been asked by someone to make them a personal doc, so I am giving it a go – I have captured old vhs footage which is 4:3 but I am doing the the film in anamorphic and the interviews gave been filmed in anamorphic, maybe was a mistake but I am still learning… How do I bring the 4:3 into the project? It’s probably something really simple?
Beverley Callow replied 17 years, 4 months ago 4 Members · 6 Replies -
Tim Wijbenga
April 23, 2009 at 12:58 pmI think it’s wise to setup you project as the majority of your material is. So in your case that’s anamorphic.
So there are two things you can do. You can put all your 4:3 material into compressor and adjust everything into anamorphic. You can either crop this material or you can have bars on either side of the screen.
But you can also just put it in fcp and render everytime you make a change in the 4:3 material.
Depending on the amount of footage the choice yours. That means if it’s a serious project and you have to make a lot of adjustments i would go for the first option.
Chris Poisson
April 23, 2009 at 7:54 pmBeverly,
Sometimes when I mix 4×3 with 16×9 material I set up a 4×3 sequence and letterbox all the 16×9 stuff. When I come to a 4×3 clip I just let it fill the screen.
The other way I sometimes work is to set up an anamorphic sequence, and when I come to a 4×3 clip I let it have bars on both sides, or blow it up in Compressor and crop off the top and bottom.
Have a wonderful day.
Beverley Callow
April 24, 2009 at 4:30 pmThanks for your helpful answers – I haven’t used Compressor yet, actually I have been studying sound in the last year and a half and I had only been making films for 2 1/2 years before that so FCP and all this is fairly new. I will definitely take the footage into Compressor and try to do something with it – unfortunately to blow it up and letterbox the 4:3 will probably affect it’s quality – it is from old vhs footage. I am not sure how to import a sequence that is in 4:3 into the 16:9 project – is that possible? Also, are you meaning pillarbox the 16:9 stuff? Won’t that cut off the image so it doesn’t look so beautiful?
David Roth weiss
April 24, 2009 at 7:02 pmBeverly,
Just import the 4×3 footage as you normally would. Put it on the 16×9 timeline. Then double click on the clip in the timeline to load it into the viewer. Now, open the Motion tab in the viewer and use the scale parameter to scale you footage in various ways to see they do. 133% should fill the screen — render it, see how looks. Next to the same footage that’s not scaled it will look soft, but you’re not going to be doing a side by side comparison, and VHS looks horrible anyway, so so what.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Beverley Callow
April 29, 2009 at 8:23 amThank you that’s the best answer – it’s working – I knew it was simple. yes it’s not going to be clear live digital but how could it?
