Activity › Forums › Adobe After Effects › How do i go about creating this effect?
  • Graham Quince
    September 8, 2023 at 8:02 am
    I think I’d try CC Ball Action – that should blob the figure. You might need mutliple layers to retain the blurs.
    If that doesn’t work, try CC Particle Systems II, that has a Source Alpha Inheritance in the particle settings so will generate particles just inside the figure. With gravity set to zero and large particles, you might get the look you’re after.
  • nitesse Rachha
    September 13, 2023 at 6:54 pm
    Thanks a lot mate! CC Ball action did help me get pretty close to it. Cheers!!
  • David Ginting
    September 18, 2023 at 12:18 am
    sure, the cc ball could work to make the effect, for the glitches efect like scratch u can use fractal noise, play the offset and make your footage as contrast as you can and then you can matte your fractal layer and your footage.
