Activity › Forums › Adobe After Effects Expressions › How do I get/copy the “red” values in properties which have expression applied?
  • How do I get/copy the “red” values in properties which have expression applied?
    Posted by Francesco Bona on August 5, 2017 at 9:59 am
    Hy, as we all know if I add, for example, a wiggle expression to an object position I’ll get the typical “red” values related to the global environment.
    My problem is perhaps a bit stupid .. But I can not in any way copy those values.
    I need to copy the global “red” value for x, y of a certain layer, in a certain time, to paste it in the position properties of another layer … but If I try to do it values change from “global” to “local”
    This means that the position is no longer related to the expression so these values are useless to me.
    Is there a way to copy red values instead of blue values?
    thanks!
    Francesco Bona replied 9 years, 1 month ago 2 Members · 4 Replies
  • Dan Ebberts
    August 5, 2017 at 4:05 pm
    There may be an easier way, but one way would be to open the Extendscript editor, run a script like this:
    var myComp = app.project.activeItem;
    var myLayer = myComp.layer(1);
    var myVal = myLayer.property(“Position”).valueAtTime(myComp.time,false);
    $.writeln(myVal);
    and copy the the result from the JavaScript Console panel.
    Dan
  • Francesco Bona
    August 5, 2017 at 5:35 pm
    I’m really sorry! I clicked “report post” instead of “replay” !!! ……
    Anyway I have no idea how to use the extendedscript toolkit …
  • Dan Ebberts
    August 5, 2017 at 7:32 pm
    OK, better idea. Select the property, then Animation > Keyframe Assistant > Convert Expression to Keyframes. Harvest the resulting value and then Undo, if necessary.
    Try not to report me this time. ☺
    Dan
  • Francesco Bona
    August 6, 2017 at 12:58 am
    ????????????That is the procedure I have used so far! I swear!
    I did not say that because I thought it was a method for newbies like me ..
    So it’s official: there’s no a simple way to do such a simple thing .. Unbelievable!
    But thank you very much ! I promise I will not report you! ????
