Activity › Forums › Apple Final Cut Pro › How do I get the rest of my third party audio plugins to show up in FCPX?
  • How do I get the rest of my third party audio plugins to show up in FCPX?
    Posted by Shea a.j. Comfort on July 8, 2012 at 9:12 pm
    Hello Everyone,
    In FCPX I can see the usual audio plugins along with Melodyne & PSP Audio stuff. However, my Altiverb and UAD plugins are not listed but also installed on my machine. How do I get FCPX to see the other plugins ins that do show up in my audio programs on my computer?
    I have repaired permissions and restarted the computer, to no help.
    I also tried to locate the plug-in folder for FCPX butto see if I could manually add the other plugins there but I could not find the proper folder where FCPx’s audio plugins are kept!
    Any help appreciated!
    Thank you,
    ~Shea
    Shea a.j. Comfort replied 14 years, 2 months ago 2 Members · 2 Replies
  • Kyle Bass
    July 9, 2012 at 2:57 am
    Final Cut Pro X uses the plug-ins located at /Library/Audio/Plug-Ins/Components and ~/Library/Audio/Plug-Ins/Components. As FCP X is a 64-bit application (with no bridge like Logic), it only accepts 64-bit Audio Units plugins. So if your UAD and Altiverb plugins are 32-bit, therein lies the rub.
    You’ll have to upgrade to 64-bit plugins when they are available. I don’t believe UAD or Altiverb have 64-bit version at the present time.
    So for now, you’ll have to stick to editing with those plug-ins in your DAW. FCP X really needs roundtripping… BAD.
  • Shea a.j. Comfort
    July 24, 2012 at 4:05 am
    Thank you, Kyle. That would explain it (I have discovered that the other plugs not showing up are not yet 64 bit…).
    Cheers,
    ~Shea
