Activity Forums Adobe After Effects How do I get pulldown putting a 23.98 comp into a 29.97 comp?
  • How do I get pulldown putting a 23.98 comp into a 29.97 comp?
    Posted by Tim Johnston on December 6, 2011 at 6:17 pm
    Just as the subject says, I’ve got a 23.98 composition that I’ve carefully timed out. I’d like to create a 60i mov file in the end, which means I need proper 2:3 pulldown applied. Is there any way to get pulldown when you put a 23.98 comp into a 29.97 comp, or do I just render the 23.98 comp?
    Thanks, y’all!
    Tim Johnston replied 14 years, 9 months ago 2 Members · 2 Replies
  • Kevin Camp
    December 6, 2011 at 6:33 pm
    60i, you’d need to render the 23.976 comp, setting the render settings to field render and selecting a pulldown cadence.
    if your comp is 23.98, make sure to set it to 23.976 fps before rendering, 23.98fps is not an accurate frame rate it’s just a shorthand name (kind of like a 2-by-4 is not actually 2 inches by 4 inches).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Tim Johnston
    December 6, 2011 at 6:57 pm
    Haha, yeah I was actually using 23.98 as shorthand! My comp and settings are all 23.976
    Thanks for the help!
    FCS 3
    AE 10.0.1.19
    ProTools 8.0.4cs2
    Mbox2Pro
    Matrox MXO2 mini
    OSX 10.6.6
    MacPro 2×2.7GHz
    8GB RAM
