Activity Forums Boris FX How do I get objects to intersect or share same z space
  • How do I get objects to intersect or share same z space
    Posted by Jake Tolbert on November 13, 2005 at 11:44 pm
    I’ve tried 3d and title containers to no avail.
    One object just sits on top of the other, no matter where the z position is set.
    I’ve seen this done in Boris, what am I doing wrong?
    Jake Tolbert
    PFS Multimedia
    Steinberg Audio Tools &
    Audio Professionals
    Forum Leader
    Jake Tolbert replied 20 years, 10 months ago 4 Members · 4 Replies
  • Stephen L. noe
    November 14, 2005 at 12:03 am
    Do you mean intersect in the same way as is described in the Boris tutorials located in the Boris reference guide? Passing through each other?
  • Mark
    November 14, 2005 at 5:58 pm
    I may be wrong on this, but I thought that intersecting planes was a feature exclusive to Red…I don’t use fx, only Red.
    Mark
  • Anne Renehan
    November 14, 2005 at 11:53 pm
    You need to nest the objects inside a 3D container and then set the rendered to Z-space or 3D model, depending on the shape of the track.
    Anne
  • Jake Tolbert
    November 15, 2005 at 5:21 am
    Thank you Anne. Your tip did the trick !! I was doing the 3D container already, but for some reason it was defaulting to 2D composite, instead of 3D model.
    Oh well. Thanks. Z-space render made it all disappear, how and why does it difers from 3D model.
    My container consisted of two layers, 2D text mapped around a cylinder primitive, that I made invisible, and an extruded EPS loge from Illustrator, which was spinning inside of the the text, which was rotation the other way.
    Just curious about when to use z-space and when to use 3D model?
    Jake Tolbert
    PFS Multimedia
    Audio Professionals
    Forum Leader
