Activity Forums Apple Final Cut Pro Legacy How do I get my film to fit this size/format in Final Cut Pro 7?
  • How do I get my film to fit this size/format in Final Cut Pro 7?
    Posted by Melissa Cordova on August 28, 2014 at 10:52 am
    1. Quicktime format at 1920×1080 resolution with audio.
    2. Videos must be no more then 720px wide, under 200MB, and in .mov format
    Thank you!
    Shane Ross replied 12 years ago 2 Members · 1 Reply
  • Shane Ross
    August 28, 2014 at 3:38 pm
    Those are not only contradictory, but lacking information. 1920×1080…AND 720? Makes no sense. The video needs to be either 1920×1080, or 1280×720. Can’t have 1920×1080 that’s 720p.
    Quicktime, by nature, is MOV format. But what codec do they want? I’m assuming H.264. So, you can compress to 1280×720 H.264 as a QT MOV. But how LONG is the piece? Because the quality of the export…the data rate…to get it to 200MB..depends on the duration of your video.
    Shane
    Little Frog Post
