Activity › Forums › Adobe Premiere Pro › How do I get footage into CC4 from a SD card?
  • How do I get footage into CC4 from a SD card?
    Posted by Hector Melendez on December 5, 2009 at 2:57 am
    How i do get footage into CC4 from a SD card? Very frustrate. Don’t know if Just copy paste into PP or import into the TL or get it thru the recorder cam. Read the help menu in PP but did not understood the concept.
    Please help.
    Ann Bens replied 16 years, 9 months ago 3 Members · 4 Replies
  • Bala Chandran
    December 5, 2009 at 5:24 am
    Copy your files from SDHC card to hard drive. Then FILE IMPORT to your project and then place it on the timeline. You did not say what format or camera. Make sure your timeline matches your format so that the project works without rendering.
    -BC
  • Hector Melendez
    December 5, 2009 at 4:54 pm
    Thanks. Well is a “Vivitar model 840xhd which it say it record in DV. But when I import into CC4 by file or clip along the video run in FF and the audio remain normal. 2min clip run in 10sec, then the last frama freeze and audio continue. Beside this, the clip runs well in Media player
  • Bala Chandran
    December 5, 2009 at 7:56 pm
    When you create a new project make sure your timeline settings match the footage you import, such as 1280×720 pixels, 30 frames etc. It will depend on what format you recorded in.
  • Ann Bens
    December 6, 2009 at 12:29 am
    Probably a codec problem.
    Run the file thru GSpot and see which codec it is you are probably missing.
