Activity › Forums › Panasonic Cameras › How do I get 2 different DVX’s to “see” the same remote?
  • How do I get 2 different DVX’s to “see” the same remote?
    Posted by Pierre on August 6, 2005 at 6:47 pm
    I’m trying to sync the timecode- but I need to get both cameras to “see” the remote.
    How do I do this?
    Michael
    Barry Green replied 21 years, 1 month ago 3 Members · 2 Replies
  • Noah Kadner
    August 6, 2005 at 7:31 pm
    All remotes use the same codes, just need to make sure both cameras are in range and setup to receive commands from the remote control.
    Noah
  • Barry Green
    August 6, 2005 at 7:34 pm
    There’s a menu setting for which remote control they’ll respond to — the choices are VCR1 or VCR2. Set those the same, and then set the switch on the remote to be the same as the menu setting. Then get both cameras close together (the remote IR sensor is on the back of the handle at the top, or on the front of the microphone). Point the remote at them and it should trigger each one equally.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available at https://www.dvxuser.com/articles/dvxbook/ and at Amazon (https://tinyurl.com/54u4a)
