Activity › Forums › Apple Final Cut Pro Legacy › How do I figure out if a DVCPRO HD tape is 24p or 30p?
  • How do I figure out if a DVCPRO HD tape is 24p or 30p?
    Posted by Dan Riley on January 12, 2008 at 12:29 am
    The 1400 deck just says 720p on the front panel during playback.
    I can capture it either way through the KONA3 and it looks pretty much the same.
    So how do you tell how it was shot so I can capture it correctly
    without having talked to the DP?
    Dan
    Jeremy Garchow replied 18 years, 8 months ago 4 Members · 6 Replies
  • Matthew Nelson
    January 12, 2008 at 12:35 am
    I don’t know the cadence of 30P but if you step through the tape frame by frame and you see a duplicate frame within a 5 frame set. The camera was in 24 mode.
  • Dan Riley
    January 12, 2008 at 1:00 am
    Thanks.
    I just put in a tape I knew was 24p and did what you said and see what you are
    talking about. GOOD. Now the tape I wasn’t sure of although we thought
    it was 30p, turns out to be 30p. No duplicate frames.
    Also I did something else. I captured the tape two ways,
    at 23.98 and at 59.94 (KONA3 DVCPRO HD Varicam).
    The 30p capture, the audio was in sync.
    The 24p capture, the audio got progressively off.
    But it sure would be nice if on the front of the Panny 1400
    it told me which it was.
    Dan
  • Walter Biscardi
    [Dan Riley] “The 1400 deck just says 720p on the front panel during playback.”
    Switch the front panel Display to User Bits. The frame rate is displayed there.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Matthew Nelson
    January 12, 2008 at 1:10 am
    Thanks Walter
    Good to know.
  • Dan Riley
    January 12, 2008 at 1:16 am
    Yes, thanks Walter.
    Dan
  • Jeremy Garchow
    January 12, 2008 at 3:04 am
    In addition to Walter’s excellent comment, you can also check this information in the Kona control panel. Click the timecode tab and choose rp188 for tc source then click the Userbits box. I am remembering this from memory as I am not in front of the machine, but that should get you close to where it is located in reality.
    Jeremy
