Activity Forums Adobe Audition How do i “Extend” Duration of a track
  • How do i “Extend” Duration of a track
    Posted by Anna Poly on December 2, 2009 at 3:56 pm
    Hello all,
    I would like your help on the following.
    1. I have an audio clip which is 3.25 secs long. How can i “extend” the duration and make it 10, 20, 60 minutes long?
    What i have done in Multitrack view:
    is to enter a Split at 2 min then another one at 3 min (3 parts )==>copy and paste part2 multiple times till it reaches 20 minutes.
    is this the correct procedure, or do you suggest another one.
    2. i have a track with music and vocals, and i want to delete the vocals and use the music only.
    I ve used the:
    Center Channel Extractor==> Karaoki drop vocals 20db
    Channel Mixer==> cut vocals
    None of them worked.
    Is there any way i can do that?
    Gerry Bayne replied 16 years, 9 months ago 2 Members · 1 Reply
  • Gerry Bayne
    December 3, 2009 at 4:40 pm
    Anna,
    Could you explain what the track you want to extend contains? Is it just something you want looped or
    to just duplicate and have it repeat? There is a “duplicate track” if you right click the sound file in
    multitrack view. You can repeat it as many times as you like.
    -G
