Activity Forums Adobe After Effects How do I export title animation from AE to work like a TITLE in Premiere
  • How do I export title animation from AE to work like a TITLE in Premiere
    Posted by Devon Brown on July 26, 2008 at 4:09 pm
    Hello All,
    I am trying to figure out the best way to export an animated title to work in Premiere. I have AE 7 pro and Premiere Pro 1.0 (I know its outdated. been a while and spent money on AE rather than Premiere upgrade).
    I know if I export it as an AVI all the black background will be part of the comp. My problem is is simply that i want the rays of light and the write on effect to act as a title would – independent vectors.
    what do i export my comp as to get that?
    Thanks as always!!
    Hugh Sullivan replied 16 years, 10 months ago 3 Members · 2 Replies
  • Bart Straman
    July 30, 2008 at 7:56 am
    hi there,
    Render with alpha. You want to put your animation layer on top of your footage in Premiere (like lower-thirds etc) or for titles.
    When your animation is done creating(in AE) add your comp tot the render queue in AE and use QuickTime as the output format. Select a codec like Animation or PNG and change the depth to RGB + Alpha.
    now you have your footage/animation with transparent background ready to drop in other applications!
    In photoshop you also need to export your layers/creation in png if you want to hold the transparency
    Bart
  • Hugh Sullivan
    October 10, 2009 at 11:02 pm
    I use Premiere Pro 2.0 and am able to bring in .psd files with no background. I’ve never tried with .png before.
    -Hugh Sullivan
