Activity Forums AJA Video Systems How do I ensure sync?
  • How do I ensure sync?
    Posted by Ron Craig on July 10, 2008 at 2:21 am
    I have a Kona 3 card running in an Octocore with Kona breakout box and the necessary small converters. I want to dub a 720p 59.94 Final Cut project to anamorphic Beta-SP. I understand how to set up the Kona Control Panel to do this. In fact, I’ve run a test and I’m getting audio and video as desired. However, there is a slightly imperceptible hum bar in the image.
    What I’m not sure of is the black burst/sync. Before I went to high def in my small edit studio, everything was kept in sync with a black burst generator, running at 29.97 (I assume). Now I have an FCP sequence that is 59.95 going to a beta deck that is 29.97. How do I manage sync? Can I deliver my standard black burst signal to the Kona card and get a proper image? Otherwise, how do I handle this situation, where the source is 59.94 and the destination is 29.97?
    Thanks very much for any guidance.
    — Ron
    Ron Craig replied 18 years, 2 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    July 10, 2008 at 3:04 am
    Since they are both base 30, you can use standard 29.97 and the Kona and the deck will accept and understand it. It’s 23.98 decks that have the tri-sync.
    Jeremy
  • Ron Craig
    July 10, 2008 at 3:43 am
    Thanks, Jeremy!
