Activity › Forums › Adobe Premiere Pro › How do I edit native (Canon DSLR) and export without transcoding?
  • How do I edit native (Canon DSLR) and export without transcoding?
    Posted by Justin Ferar on June 4, 2014 at 7:30 pm
    Classic Premiere conundrum. You don’t have to transcode to start editing but you do when it comes time to export. Time is money!
    I’ve been humming along editing native DSLR footage with PRORES as the render codec. Great. But Isn’t there a way to just change the render codec to the same native h.264 and export without any transcoding? This is cuts only with no grading. I’ve tried creating a new sequence with H.264 as the preview codec but it still wants to do a lengthy re-compress upon export.
    This would be the fastest workflow possible. Can Premiere do this?
    Premiere CC 7.2.2
    MacPro Hexacore
    Kevin Monahan replied 12 years, 4 months ago 3 Members · 7 Replies
  • 7 Replies
  • Alex Udell
    June 4, 2014 at 7:44 pm
    In some software in the past, and under Quicktime architecture, you could create “virtual clips” that were essentially containers with pointers to the underlying media files.
    The next step was “smart rendering,” where by, rendering and exporting with some codecs was sped up by simply “copying and pasting” render files as part of the final export as long as it was the same codecs as the source and no new media needed to be generated for things that didn’t visually exist in the stream (thinks like color changes, transitions, titles really anything that generated a unique frame).
    While PPro does support Smart rendering with ProRes and XDCam codecs (I think)…h264 is not one of those areas where smart rendering is supported to my knowledge. So new media needs to be created on the way out, regardless of the simplicity of the edit in the timeline.
    That’s my understanding…
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Justin Ferar
    June 4, 2014 at 8:24 pm
    Sometimes I miss that software from the past.
  • Justin Ferar
    June 4, 2014 at 8:27 pm
    Alex, does Andre Agassi know you are using his avatar? :=)
  • Alex Udell
    June 4, 2014 at 8:28 pm
    lol…that’s awesome!!!
    Alex Udell
  • Kevin Monahan
    June 4, 2014 at 9:51 pm
    Hi Alex,
    Yes, you’ve pretty much got it right. Justin, if you want more info on smart rendering and what to expect in Premiere Pro, here’s a video by reTooled.net:
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Premiere Pro New Features – Smart Render for ProRes and Preview Files from reTooled.net on Vimeo.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Justin Ferar
    June 4, 2014 at 11:57 pm
    Thanks guys.
    Add H.264 to “Smart Render”.
    Feature request submitted…
  • Kevin Monahan
    June 5, 2014 at 5:28 pm
    [Justin Ferar] “Feature request submitted…”
    Thanks, Justin. Recently, I asked engineering if it was possible for H.264 smart rendering. The answer was, “yes.” So, things might change in the future. Let’s hope so!
    Kevin
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
