Activity Forums Adobe Premiere Pro How do I duplicate a clip from the timeline, convert it to slow motion and return to timeline?
  • How do I duplicate a clip from the timeline, convert it to slow motion and return to timeline?
    Posted by Joseph Hayhurst on January 22, 2013 at 2:42 am
    In a soccer video I want to duplicate a scoring clip from the timeline, turn it into a slow motion clip, add a title, “Let’s see that again in slow motion”, then return it to the timeline after the regular speed clip so that you see the score in real time and then repeat the score in slow motion. I don’t know how to duplicate the scoring clip, turn it into slow motion, add the title, then return the slow motion clip to the timeline. Help please.
    edokie
    Jeff Greenberg replied 13 years, 7 months ago 2 Members · 3 Replies
  • Jeff Greenberg
    January 22, 2013 at 2:10 pm
    This is probably the fastest way (there are others). You don’t need to remove it from the timeline, merely duplicate it and slow it down.
    Copy the clip (Control-C)
    Paste Insert (Control-Shift-V) the clip at the playhead.
    Select the 2nd clip.
    Clip menu > Speed Duration (or Control R)
    Set the amount of speed reduction you’d like and choose “Ripple editing, shifting clips”
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
  • Joseph Hayhurst
    January 22, 2013 at 5:07 pm
    You make it sound easy, but I’m missing some steps. How do I copy a clip and get it into the source monitor to trim? When you trim a clip on the timeline do you have to rename it and put the trimmed clip in the project with another name? I finally did get a copy of the soccer scoring clip in the timeline and and increased the duration of the new clip, but then only the first part of the clip shows in slow motion. I guess I need to make more room for the longer clip duration but it didn’t happen. I can’t find the “choose Ripple editing, shifting clips” that you said to do, I right click on the clip and there is no choice for that. What do I do to find that option, and when and where do I apply it? Thanks for your time.
    edokie
  • Jeff Greenberg
    January 23, 2013 at 3:35 am
    Well,
    I’m using Adobe Premiere Pro CS6 – what version are you using?
    [joseph hayhurst] “When you trim a clip on the timeline do you have to rename it and put the trimmed clip in the project with another name?”
    No, that would be if you duplicated a clip in the browser. We’re using the same clip a second time in the timeline. Adobe Premiere Pro treats the duplicated clip in the browser as two separate clips; but if you duplicate the one in the the timeline, it’s the original clip used twice.
    [joseph hayhurst] “, I right click on the clip and there is no choice for tha”
    Clip Menu > Speed Duration.
    If you’re using an older version of Premiere Pro it may be different!
