Activity Forums Adobe After Effects How do I do this: making crayon lines
  • How do I do this: making crayon lines
    Posted by Esther Diepenhorst on November 23, 2010 at 1:21 pm
    Hello, I have a question about something I want to use in an animation I am making with After Effects.
    I want to use the brushtool to draw items but I wanted the lines to look just about the same as the ink lines you have in Illustrator. In other words, rough edged lines that I can bend and animate further. I do not want to make it frame for frame with Illustrator. Is there a way to import that brush to After Effects?
    How can I make those lines in After Effects?
    Scott Novasic replied 15 years, 9 months ago 3 Members · 2 Replies
  • Michael Szalapski
    November 23, 2010 at 2:40 pm
    Check out this tutorial. It’s on chalk lines, but the same principle would apply.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Scott Novasic
    November 24, 2010 at 1:38 am
    using a write on effect and a noise alpha plug on top if it can be a quick and dirty way to get the same general look…
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
