Activity Forums Adobe After Effects How do I do this? – Filling Arrows
  • How do I do this? – Filling Arrows
    Posted by Sean Lilley on May 1, 2024 at 1:33 pm
    Hi, I’m fairly new to after effects. What I need to do with this image is basically transform it into four different animations for a video:
    1. So I need the image to start dim – and then the red courage arrow lights up/fills up with colour – from bottom to top of arrow – then the centre purple circle lights/fills up.
    Then the same with the three other arrows.
    2. Whole image dim – orange connected arrow fills up – then the centre purple circle fills up.
    3. Whole image dim – green empathy arrow fills up – then the centre purple circle fills up.
    4. Whole image dim – blue authenticity arrow fills up – then the centre purple circle fills up.
    Hope that makes sense. Any help with this very much appreciated!
    Eric Santiago replied 2 years, 4 months ago 3 Members · 2 Replies
  • Hector Vera
    May 1, 2024 at 4:00 pm
    It seems that you will need to create some different layers so you can add to the composition. I remember when I did animation in photoshop, you have to create multiple layers which at first the solid objects needs to start off DIM and slowly becoming brighter. I found these steps online that may give you an idea step by step on how to execute correctly your first animation on After Effects! Best of luck!
  • Eric Santiago
    May 1, 2024 at 6:06 pm
    I’ve done many of these in the past.
    Great thing about AE is you can create one and re-use in many ways.
    You will need to deal with masking parts as well.
