Activity Forums Adobe After Effects How do I do this effect
  • Georgi Zhekov
    August 6, 2007 at 1:11 pm
    I guess that Trapcode Particular would do the job,for more info visit
    Trapcode.com for info about using the plugin you should check the download section of the site mentioned,of course here on the COW there’re plenty of tutorials for this plug-in.One of my favourites is
    Andrew Kramer’s
  • Ben Hawkins
    August 6, 2007 at 2:07 pm
    It does not need to be trapcode. You can get a free trial for trapcode but it does cost money. you should be able to do this effect with the CC partical world and partical system. which if you have AF7 pro should be under the effects > simulation.
    from what I saw in that video is most of those effects were partical generators.
    just play with around with them
    also, the previous post is correct, look up Andrew on this site, he is very good
    Partical slaughter
    Ben
    I got the hottest beats and the softest fur.
  • Big Beres
    August 6, 2007 at 10:08 pm
    Thanks for your input. I guess it’s just knowing where to start with CC partical worlf and partical system
    BB
  • Brian Lynn
    August 8, 2007 at 1:31 am
    CC Particle World is in 7? I thought it was CS3? All my 7 has is Particle Playground, which is either way out of my comprehension to use, or its no where near as powerful as my other two, Particular and ParticleIllusion. I have a hard time even getting just round particles with Particle Playground. I can’t wait to have CC Particle World…
  • Brian Lynn
    August 9, 2007 at 5:59 am
    Ok I am a idiot… helps to look through my entire CD before I post! lol…
