Activity Forums Apple Final Cut Pro Legacy How do I delete Easy Setups?
  • How do I delete Easy Setups?
    Posted by Pkdumas on March 6, 2007 at 3:44 pm
    I’ve created some custom Easy Setups, but would like to delete them now. In Finder, I went into the Final Cut Pro System Support > Custom Settings folder and found the files, but after trashing them, they still showed up in the FCP application. Any ideas on how to delete these setups?
    thanks
    Jeremy Garchow replied 19 years, 6 months ago 4 Members · 3 Replies
  • Motionfx
    March 6, 2007 at 4:00 pm
    Not sure about that one but here is the link for trashing prefs. Good luck.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    Brian
  • Debe
    March 6, 2007 at 4:59 pm
    Did you try just deleting them with the Delete button in the Audio/Video Settings in the Capture Presets or Sequence Presets tabs (depending on which kind of Easy Setup you created)?
    debe
  • Jeremy Garchow
    March 6, 2007 at 6:54 pm
    You have to trash your prefs after doing this.
