Activity › Forums › Apple Final Cut Pro Legacy › How do I delete all transitions in one mouse click?
  • How do I delete all transitions in one mouse click?
    Posted by Josh Evans on September 29, 2005 at 8:44 am
    I need to delete all the transtions in an entire sequence. rather than go in and do it manually, is there a way of just deleting them all in one click of the mouse?
    Also, same question RE Effects?
    Thanks guys
    Tom Meegan replied 21 years ago 3 Members · 2 Replies
  • Jerry Hofmann
    September 29, 2005 at 3:05 pm
    Don’t think so.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Tom Meegan
    September 29, 2005 at 7:50 pm
    In another sequence create a 1 frame dissolve. Save as a favorite.
    Set your default transition to this 1 frame dissolve. Select all in the sequence you want modify. Drag to the canvas and drop on “Overwrite with Transition.”
    Although this doesn’t do what you wanted, it does give you cuts very quickly. Unless there is a tiny dissolve between fields? Let me know if I’m wrong.
    Regards,
    Tom
