How do I delete a region with no number
Posted by Doyal Gudgel on May 22, 2011 at 2:07 pmHow do I delete a region when it doesn’t have a number? Help says to r click the number and delete. “Delete all” does not delete because it doesn’t have a number as far as I can tell. This in vegas 9.
Hope to see you
https://seniorobserver.blogspot.com, https://billswar2.blogspot.comDoyal Gudgel replied 15 years, 3 months ago 2 Members · 5 Replies -
John Rofrano
May 22, 2011 at 2:51 pm[doyal gudgel] “How do I delete a region when it doesn’t have a number? Help says to r click the number and delete”
If you right-click on the region marker it should still give you a delete option even though it runs out of numbers at 99.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Doyal Gudgel
May 23, 2011 at 4:22 pmI am pretty sure I tried to do that obvious solution but I will try it again
Hope to see you
https://seniorobserver.blogspot.com, https://billswar2.blogspot.com -
Doyal Gudgel
May 23, 2011 at 6:54 pmApparently this is not a region because if you right click on it it asks if you want to create a region. If you say yes it displays region separage from the display you want to get rid of. Here is a picture of what I want to delete.
Hope to see you
John Rofrano
May 23, 2011 at 7:48 pm[doyal gudgel] “Here is a picture of what I want to delete.”
That is not a region. It’s a timeline selection or loop region. There is no reason to delete it because it is transient. Simply drag your mouse over the timeline somewhere else and it will make a new selection there. If they bother you, go into Options | Preferences | Editing and check the box that says, “[x] Collapse loop region when no time selection is present” and then will collapse when your not using them.
~jr
Doyal Gudgel
May 24, 2011 at 12:17 amOK Fine. Appreciate it It had me worried
D
Hope to see you
