Activity Forums VEGAS Pro how do i crop or feather edges?
  • how do i crop or feather edges?
    Posted by John Corino on December 2, 2005 at 6:04 pm
    My problem is this. I recently taped an interview but in the top right hand corner there is a lens flare. So what I planned on doing was putting the video on two tracks. I wanted the first track to be used for a matte where I would use the pan/crop tool, focus in on the background canvas and then move it to cover up the lens flare. The problem with this is that when I cover up the lens flare, there is a hard black edge that I need to either crop out (which doesn’t seem to work with the pan/crop tool) or feather the edge so that it disappears. Does anyone know how I can do this? I remember there was a plugin for cropping but I don’t remember where it is.
    Donatello replied 20 years, 9 months ago 2 Members · 1 Reply
  • Donatello
    December 2, 2005 at 6:18 pm
    in pan crop expand PATH .. use the anchor creation tool to cut the hole ( cut out lens flare) in the frame .. then use feather type and feathering to soten the edge …
    or you could use the cookie cutter to cut hole in frame …
