Activity › Forums › Adobe After Effects › How do I create this gowing flourish?
Posted by Sean Tatalovich on February 21, 2009 at 2:09 amI am trying to figure out the best way to create a growing animation like this one at the bottom left where the flower grows.
https://www.videocopilot.net/products/evolution/evolution_features/
Is the best way to do this to make a mask over it and reverse the frames?
Stephen Smith replied 17 years, 2 months ago 3 Members · 4 Replies -
Scott Novasic
February 21, 2009 at 2:25 amok the smart aleck answer is to buy it!
Otherwise its rather easy to create. That said, its pretty time consuming. First you need the design sense to make an attractive flourish in Photoshop or Illustrator (my choice) then using a number of hand masks animate a wipe reveal at various frame rates. All this is seasoned “to taste” as far as pacing and the number of masks. Depends how much effort you want to put in. Me, im way old school, I believe in putting in the handwork in a detailed way giving me the most flexibility as far as options go. Pre comp elements to also do an animated scale
‘wobble’ as the pieces reveal. You may not need to pre comp based on what your final goal is.Good luck..
SuperNova
Animation & Visual Effects
Scott Novasic
Los Angeles Ca
web:https://web.mac.com/finaleffects -
Sean Tatalovich
February 21, 2009 at 2:56 amwhat do you mean by
Pre comp elements to also do an animated scalethanks
Scott Novasic
February 21, 2009 at 3:10 amwell, pre comping is a basic AE task that involves taking multiple layers
and ‘combining them into one so you can more easily universally apply effects or transition to those elements alone. Its hard forme to advise you if you are unaware of basic pre comping.Respectfully, consult your AE manual on how to, and what pre comping is.
good luck….
SuperNova
Scott Novasic
Los Angeles Ca
Stephen Smith
February 24, 2009 at 10:41 pmThis tutorial should be of great help.
https://library.creativecow.net/articles/hansen_jaysen/growing.php
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
