Activity Forums Apple Final Cut Pro Legacy How do i create this effect in final cut pro x?
  • Shane Ross
    July 21, 2013 at 5:14 am
    That’s a light leak that is layered with footage that is sped up. Light leaks can be found here:
    https://editwithlight.com/
    And you COMPOSITE them, screen mode. HOW in FCX? No clue. But I use this all the time in FCP 7 and Avid.
    Shane
    Little Frog Post
  • Veronica Lucero
    July 21, 2013 at 5:22 am
    thanks for the feed back, i appreciate it but the effect i am trying to achieve is the rapper shakes is head that movement is what i am trying to master, any idea how i can do that?
