Activity Forums VEGAS Pro How do I create the “Wonder Years Opening” look (rounded corners)?
  • How do I create the “Wonder Years Opening” look (rounded corners)?
    Posted by Brent Lumkin on May 29, 2007 at 11:50 am
    Here is the opening just to show you in case you need a refresher on what it looks like:
    https://youtube.com/watch?v=jZ-GU8Py3XQ
    I know how to position the video by zooming out to create the black space and all of that. All I need to know how to do is to give the actual video portion the rounded corners look. Any help would be appreciated, thanks!
    Accountclosed replied 19 years, 3 months ago 3 Members · 2 Replies
  • Josh Meredith
    May 29, 2007 at 12:59 pm
    There are two ways I would try:
    1 – use the Sony Cookie Cutter plug-in, select “rectangle”, and adjust the size & feather controls to get the look you want.
    Or…
    2 – create a GIF or PNG in Photoshop, which consists of nothing but a black border with rounded corners, with a transparent center. Then just place the image over your video track in Vegas.
  • Accountclosed
    May 29, 2007 at 1:04 pm
    hmmm ok i’ve already answerd this on jetdv.com but here is again…
    peace of cake in vegas
    see that pic
    1st insert your Video then insert another video track and from media generators tab insert the color gradient on the above layer…
    hopoe you understand …
    copy and past this link into your browser to see sample image
    https://tinypic.com/view.php?pic=61j8xow
