Activity Forums Maxon Cinema 4D How do I create like a echo trail in C4D (kind of like a superman effect)
  • How do I create like a echo trail in C4D (kind of like a superman effect)
    Posted by Daniel Bent on April 21, 2014 at 11:25 pm
    I doing a project in Cinema 4d, How do I do create a chryon or echo trail effect in C4D? I know how to do it in AE, but can you do it in cinema 4d? Here’s an example from these two images.
    Daniel Bent replied 12 years, 4 months ago 3 Members · 3 Replies
  • Brian Jones
    April 22, 2014 at 4:13 pm
    the superman effect is very easy, it’s just text extruded (or you could sweep text along a spline for a shaped extrude rather than straight out in that example) with a white texture on the front face and a transparent blue on the rest.
    The Buena Vista looks like the text swept on a spline kind of shape but the blurriness would be a lot easier in post, it might be possible with depth blur with real tight control (or some other method) but I don’t know.
  • Tony Barone
    April 22, 2014 at 7:10 pm
    I put together a setup that achieves what you may be going for. You can easily change the text and the extrusion length to your liking.
    7388_texteffect.c4d.zip
  • Daniel Bent
    April 23, 2014 at 11:17 am
    Okay. The Superman text works for me. Thanks for the C4D Project File. And Thank you for helping! 🙂
