Activity Forums Adobe After Effects How do I create burned-in timecode in AFX?
  • How do I create burned-in timecode in AFX?
    Posted by Michael Hussar on March 31, 2009 at 7:39 pm
    Hello all,
    I searched through the forums and tuts but surprisingly could not find this issue addressed. Perhaps I used the wrong search terms.
    I’m using AFX CS3 on Win XP Pro SP2.
    I know there must be an easy way (script, effect, trick etc) to show the real-time timecode in the comp for a given animation.
    Thanks in advance.
    MH
    Michael Hussar replied 17 years, 5 months ago 2 Members · 2 Replies
  • Dave Johnson
    March 31, 2009 at 7:53 pm
    From the Effects menu, choose:
    Text > Timecode
    or
    Text > Numbers and set the Type to Timecode.
    The differences between the two approaches are pretty intuitive so I’m sure you’ll determine which is best for what you need pretty easily.
  • Michael Hussar
    March 31, 2009 at 8:31 pm
    thank you 🙂
