Activity › Forums › Apple Final Cut Pro Legacy › How do I create a split scrren that doesn’t lock to the image?
  • How do I create a split scrren that doesn’t lock to the image?
    Posted by Per Rönnecke on October 4, 2007 at 8:57 pm
    Hi!
    This maybe is a basic question, but I haven’t yet found any solution.
    I have to create a split screen with three vertical images. Then I have to move the picture within the split so that the people moving in the image is visible in the split.
    Everything that I have tried so far makes the split edge move with the image.
    Any solution?
    /Per
    Per Rönnecke replied 18 years, 11 months ago 4 Members · 8 Replies
  • 8 Replies
  • Russell Lasson
    October 4, 2007 at 9:00 pm
    I’d use the alpha matte blending mode. Then use solids to define the areas to be split. You’ll end up with quite a few layers.
    -Russ
  • Per Rönnecke
    October 4, 2007 at 9:10 pm
    Thank’s Russel! That should be working. As you said, some layers!
    It was easier in the old days with a linear switcher….and some b-rolls 🙂
    Thanks again!
  • Bouncing Account needs new email address
    October 4, 2007 at 9:11 pm
    You need to download the FCP plugIn called DH Box-
    https://www.digital-heaven.co.uk/fcplugins/dh_box.php
    Take a look at the demo.
    The plugIn costs…
    $20.00
  • Per Rönnecke
    October 4, 2007 at 9:24 pm
    Thanks, Matte!
    I have downloaded the demo and will try it tomorrow. Seems to be something I’ve been looking for. Almost like the old fashion way 🙂
    Thanks again!
    /Per
  • Chris Poisson
    October 5, 2007 at 11:58 am
    For track mattes with solids I use “travel matte luma.” I use this A LOT, it is very flexible and easy to keep track of by using a specified color matte for each layer, a little trick I found. That way you can quickly tell which matte you need to move.
    I usually just use the matte generator and the crop sliders. it is a very fast and clean workflow.
    DH Box is very good, but I don’t think it’s as quick as dragging things in the canvas. Render times are probably a wash.
    Have a wonderful day.
    October 5, 2007 at 1:48 pm
    [Chris Poisson] “DH Box is very good, but I don’t think it’s as quick as dragging things in the canvas. Render times are probably a wash.”
    But for $20, its a miracle.
  • Chris Poisson
    October 5, 2007 at 8:13 pm
    Still not as flexible as using travel mattes in my opinion. But very good.
  • Per Rönnecke
    October 5, 2007 at 8:22 pm
    Thanks, all! I used the travel matte and I’m at the moment satisfied. I didn’t try the DH-Box, but I will when I don’t have a deadline 🙂
    /Per
