Activity › Forums › Adobe After Effects Expressions › How do I create a simulated “camera shake” effect (like an earthquake) in AE6.5?
Posted by Accountneedsrealnameupdate on April 6, 2006 at 8:19 pmThis relates to my other post, as I have a ‘camera shake’ FFX file, that I can’t figure out how to install. So I’m wondering how can I create a camera shake effect from scratch? Basically I want to shake all the items on the screen as if an earthquake or strong thunder is shaking the camera. Anyone know how to do this?
Visionary Films replied 20 years, 3 months ago 7 Members · 8 Replies -
Lazlo Hollyfeld
April 6, 2006 at 8:27 pmUse the wiggler palette in conjunction with the X & Y position of the keyframes.
Arie
April 6, 2006 at 8:34 pmI have AE Std not Pro, so I dont have the wiggler. Any other way?
Mike Clasby
April 6, 2006 at 9:01 pmQuaker, an Animation Preset free from Scott Frizzle. It’s a gem.
https://scottfrizzle.com/free.html
PDF avalable, although I don’t see a link on his site now, but I just downloaded it:
https://scottfrizzle.com/images/quaker.pdf
Ryan Hill
April 6, 2006 at 9:04 pmDo you still have expressions?
https://www.creativecow.net/articles/kahlenberg_roland/expressions/index.html
Mike Clasby
April 6, 2006 at 9:09 pmQuaker, an Animation Preset free from Scott Frizzle. It’s a gem.
Installation instructions in the PDF.
Harryjf
April 6, 2006 at 9:18 pmIf this is the same as the other tutorial linked to, sorry. But I’ve written this one for my AE class and my students really like it.
Creating A Simple Camera Shake Using Motion Tile and Expressions
1) Apply Motion Tile to your video that you want to have the camera shake on
2) Apply an Expression Slider (Effects>Expression Controls>Slider)
3) On the “Tile Center” parameter, create an expression. (Option click on the stopwatch)
3) Enter for the expression:
wiggle(5,effect(“Slider Control”)(“Slider”));
4) Keyframe the expression slider to create the camera shake. Usually, you’ll want an abrupt change, then it decays to zero.
5) Turn on Motion Blur for the composition and the layer.
6) Turn on “Mirror Edges” in the Motion Tile settings.
You might need to crop your original video if you’ve got visible horizontal blanking on the edges. just precomp it and scale it up.
Scott Frizzle
April 7, 2006 at 5:21 pmHey, just a quick note for those of you using the Quaker animation preset: I’ve discovered that for some reason if you’re using Quaker on an adjustment layer (my preferred method) in AE7, you get borders between the image tiles. I don’t know why this is, as this method works fine in AE 6.5. I haven’t found a fix yet, and I’m no sure there is one, but I just thought I’d let you know since I haven’t posted aboything about this on my site.
Visionary Films
June 5, 2006 at 3:50 amHello!
I’m needing some urgent help here to complete a music video. okay…i have 6.5 A.E. Standard, i’ve tried for like 4 hours to get this rather simple effects, i read over the instructions and its still not working, 6.5 doesn’t have wiggler and i’ve tried everything else from the lil print out using expressions and the slider control, still doesn’t work.
is there a filter plug in i can use or can some one guide me through this 4 secons effect i have in my music video.
Rick
Richard Carr
Founder & Director
Enchanted Storms Production
Louisville, KY 40218
502-671-1274
https://www.myspace.com/enchantedstorms
