Activity Forums Adobe After Effects How do I create a paint splatter effect?
  • How do I create a paint splatter effect?
    Posted by Janeee on January 25, 2006 at 5:57 pm
    I need to create some kiddy style paint splatters and splodges in after effects 6.5. Is there a plugin I can download to acheive a realstic effect? It would be good to have the paint splatter running down the screen after impact.
    Janeee replied 20 years, 8 months ago 5 Members · 5 Replies
  • Troy Anderson
    January 25, 2006 at 6:48 pm
    Frankly, I’ve had the best results by throwing white paint onto a black surface, then compositing different takes. I clamped a piece of low-glare glass to a piece of foam core and hurled paint at it.
  • Charley King
    January 25, 2006 at 8:43 pm
    White paint on a black card works well too. The first time I did that was in the 1960’s. Dang if it doesn’t still work. Loved to make a paint wipe for those Horror movie promos. Just took a black card at an angle and poured paint across the top and let it run down, but I have to admit the last time I didn’t have any white paint so used yellow on black.
    Charlie
    ProductionKing Video Services
    Unmarked Door Productions
    Flamingo Las Vegas Hotel
    Las Vegas, Nevada
  • Dan Asselin
    January 25, 2006 at 9:37 pm
    If you want particle illusion has what you are looking for pre-built.
    Dan
  • Graham Quince
    January 26, 2006 at 8:53 am
    I hate to post this because I think pratical effects produce way better results. But….
    You could do this simply by creating bezier masks on a coloured solid. Keyframing the Mask Expansion, from a negative amount to 100% over a couple of frames will give up a splatt. And of coure, you won’t get covered in paint splashes.
    Not as much fun, but no clearing up to do.
    Graham
    https://www.qcit.co.uk – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
  • Janeee
    January 26, 2006 at 12:14 pm
    Thanks so much for your help. Would love to get messy with the paint but will have to stick with the ol’mask expansion for now….cheers!
