How do I create a mask that tracks its position in the source file?
This may be an After Effects 101 question, but I’ve spent a lot of time looking for an answer so here goes.
Let’s say I have a poster on a wall that I want to remove. The camera is panning past the wall, so it needs to be tracked. I could time-freeze the video, make a patch out of another portion of the wall using a mask, and then track that still-frame patch over the poster and it’s gone. But, what if there are constant light changes on the wall from passing cars? How do I create a patch that changes dynamically with the source footage it is masked from?
My usual workflow is: Instead of time-freezing anything, I duplicate my layer, stabilize it so that the section I want stays in the same place for the whole duration, then mask that section and attach it to the tracked object I want removed. This is tedious and almost never works as well as I’d like.
I am sure there is a built-in way to do this, right? What’s the easiest way?
