Activity Forums Adobe InDesign How do I create a 8.5″ x 50″ and tile print it so its spans 4-8.5″ x 14″ sheets
  • How do I create a 8.5″ x 50″ and tile print it so its spans 4-8.5″ x 14″ sheets
    Posted by Sebastian Knight on September 26, 2007 at 6:47 pm
    I want to create a document that will be 8.5″ x 50″ that I have it printed on 4-8.5″ x 14″ sheets through my printer, which I then cut and tape together. How do I do this in InDesign CS?
    Thanks in Advance for your reply,
    Sebastian
    Thank You in advance for taking the time to read and reply to my Post.
    Sebastian
    Mike Gondek replied 18 years, 11 months ago 2 Members · 3 Replies
  • Mike Gondek
    September 27, 2007 at 8:12 pm
    2 reasons you need more that 4 pieces of paper to tile your job.
    1) Most printers do not print to the edge of teh paper, because the gripper has to grip the paper without ink/varnish adn that is what keeps your printer clean form loose toner/ink.
    2) You need overlap (.125″ minimum), to register your prints against.
    You will need 8 pieces of paper to do this. Now if you document was 8″ x 40″, you could then do it on 4 pieces of legal paper.
  • Sebastian Knight
    September 27, 2007 at 11:34 pm
    Thank you fo that, but how do I print a tiled document?
    Sebastian
  • Mike Gondek
    September 28, 2007 at 12:16 am
    file >> print
    Choose setup underneath general on options at left
    enable tile and set an overlap
