Activity › Forums › Adobe Premiere Pro › How do i correct chnging light levels?
  • How do i correct chnging light levels?
    Posted by Tim Bond on December 8, 2005 at 3:29 pm
    I’ve been given some footage that was shot, hand held on a PD170, in a marquee. As the clouds have shifted outside i’m left with fading up and down light levels. Is there a way of evening out the level without me trying to match it frame by frame by eye?
    Tim
    Tim Bond replied 20 years, 9 months ago 3 Members · 5 Replies
  • Tim Kurkoski
    December 8, 2005 at 5:25 pm
    Some of the adjustment effects in Premiere Pro have “auto” options that will attempt to do this. It can be processor intensive, though, so make sure to render the timeline.
  • Tim Bond
    December 8, 2005 at 9:14 pm
    Any suggestions of what to try first? Or if there’s a combination of effects that might sort this out?
    Tim
  • Tim Kurkoski
    December 9, 2005 at 4:36 pm
    It’s hard say without seeing the footage first. Shadow/Highlight or Auto Levels would probably be my first stop. Levels can introduce color casts, though (color cast could also be a problem with changing light conditions anyway), so you might also need to toss on Auto Color. I usually have to experiment for a while before I find a combination of filters that works the way I want.
  • Ruby Gold
    December 9, 2005 at 5:21 pm
    I just recently used auto color and auto contrast, individually and in combination, to correct changing light conditions in some footage and they worked really well. The auto contrast introduced a little bit of flickering in some cases, but not all, and after playing with the two a bit, I found a combination that worked.
  • Tim Bond
    December 11, 2005 at 2:46 pm
    Thank you both – gives me somwhere to start.
    Tim
