Activity Forums Adobe After Effects How do i copy the anchor point of a layer to somewhere else without moving the layer?
  • How do i copy the anchor point of a layer to somewhere else without moving the layer?
    Posted by Josh Brine on October 15, 2012 at 6:58 pm
    im pretty sure there is a method/hotkey to make this happen
    i have a graphic layer, and a txt layer below it. i want to scale them both to the centre of the graphic layer instead of manually placing the anchor point to the center of the graphic i want to copy and paste the anchor point data from the graphic to the txt, but it moves the layer in relation to the movement of the AP, how do i prevent this position movement from happening?
    Darby Edelen replied 13 years, 10 months ago 2 Members · 1 Reply
  • Darby Edelen
    October 16, 2012 at 1:16 am
    In your case you can parent the text layer to the graphic layer and then scale the graphic layer.
    Darby Edelen
