Activity Forums Adobe Premiere Pro How do I combine all my 7D footage into ONE file??
  • How do I combine all my 7D footage into ONE file??
    Posted by Shamus Coneys on June 16, 2012 at 3:14 pm
    I am still using CS4 for 1 more project, than am installing my CS6.
    My question is this:
    For a project i am working on…I would like all my 7d clips to be merged into ONE.
    Is there a way to take all my clips and have them be ONE scrubbable file without exporting all of them
    to create the one large file??
    Your help is greatly appreciated.
    Casey Petersen replied 14 years, 2 months ago 3 Members · 3 Replies
  • Jon Barrie
    June 17, 2012 at 2:38 am
    Can you explain why you want it all in one continuous clip?
    CS4 does not have any smart rendering so you will get a quality hit exporting to one clip with the same H.264 codec used with the source footage.
    Going to Uncompressed is the only true way to not lose any quality, but then you’ll get slammed on the HDD space used.
    I’d like to know why you want to have one clip as opposed to using a nest and loading that as a “clip”, reducing the need to make more media and potentially lose quality.
    To load a Sequence and use as a clip that can be added to another sequence (Nesting) hold the Control(Command) Key down when you double click the sequence. It will load into the Source Monitor. You could also just drag the sequence icon from the project panel into the source monitor.
    Or what I do is add the entire sequence as a nest and edit in the timeline. Setting in and out points around the sections I don’t want and using lift or extract to remove them, leaving only the bits I need in the sequence…
    Sorry that was a lot of detail… for a rather simple question.
    Cheers JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Shamus Coneys
    June 17, 2012 at 3:16 am
    Thank you JB, very informative.
    I shoot weddings, so I come home with 500 clips that are all 15 seconds long..lol.
    It takes forever to go through it….it’s much more efficient to have one large file to scrub through.
    I understand the quality loss and figured there is a way without exporting.
    Thanks again for your info!
  • Casey Petersen
    June 22, 2012 at 7:47 pm
    MPEG Streamclip gives you the option to “Join All the Files” when running a batch list.
