Activity › Forums › DaVinci Resolve › how do I colortrace to a sequence in same project?
  • Eric Hansen
    April 5, 2013 at 9:21 pm
    in the conform window, right click on the sequence you want to ADD grades to, click Colortrace
    then it will ask what sequence you want to use as the source. select your current project and the source sequence in the drop down.
    i’m hoping this is changed in Resolve 10 to make choosing and copying grades easier.
    e
    Eric Hansen
    Production Workflow Designer / Consultant / Colorist / DIT
    https://www.erichansen.tv
  • Andrew Sableton
    April 5, 2013 at 9:26 pm
    the problem is when I look in that window it gives me the option to select any project except my current one
  • Joseph Owens
    April 5, 2013 at 9:27 pm
    If the clip has the same identifiers, it should auto-link through the Master Timeline, unless you’ve got this function turned off.
    If it doesn’t, it is doubtful that ColorTrace will work automatically, and you will be into a manual trace.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Jake Blackstone
    April 7, 2013 at 3:51 am
    Make a copy of a project and then copy grades from another timeline of your old project.
