Activity › Forums › Adobe After Effects › How do I click and drag an edge of a mask without dragging the rest of the mask with it?
  • How do I click and drag an edge of a mask without dragging the rest of the mask with it?
    Posted by Darragh Griffin on September 18, 2013 at 10:17 pm
    Hi
    How do I click and drag an edge of a mask without dragging the rest of the mask with it? I just want to expand that edge of the mask by clicking and dragging that edge? Thanks
    Darragh Griffin replied 13 years ago 3 Members · 3 Replies
  • Todd Kopriva
    September 19, 2013 at 2:34 am
    See this part of After Effects Help:
    https://helpx.adobe.com/after-effects/using/animating-shape-paths-masks.html#select_masks_segments_and_vertices
    After Effects team blog
  • John Cuevas
    September 19, 2013 at 11:35 am
    And if you don’t want to read all of that, twirl open your mask and click on path, then use selection tool(the arrow) draw a rectangle around the areas you want to select. Then move them.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Darragh Griffin
    September 19, 2013 at 2:50 pm
    Johnny, thanks a lot for your advice. Works a charm!
