Activity Forums Adobe Premiere Pro How do I choose the left channel only in audio?
  • How do I choose the left channel only in audio?
    Posted by Mike Schmitt on February 28, 2007 at 12:37 am
    Hi there:
    Just shot a short using my HVX 200, I had a shotgun mic piped through the left and right channel. The left channel I kept the level low, the right side I kept it higher.
    now that I’m editing the right side is totally blown out and I can’t figure out how to select the left channel only.
    How do I do this?
    George Socka replied 19 years, 7 months ago 3 Members · 2 Replies
  • Vince Becquiot
    February 28, 2007 at 12:44 am
    Before editing, in your project panel select the clip(s), thengo to Clip > Audio Options > Break out to Mono.
    Pick the side you want and drag it below the timeline to create a new mono track.
    Vince
  • George Socka
    February 28, 2007 at 3:44 am
    Audio effect — fill left ( or is it fill right? ) dyslexic today. It will sound right ( no pun intended ) when you chose the right ( still no pun intended )effect.
