Activity Forums Apple Final Cut Pro Legacy How Do I Change Cinewave Output Frame Size
  • How Do I Change Cinewave Output Frame Size
    Posted by Springer on April 22, 2005 at 7:15 pm
    I’m capturing DVC Pro50 from Panasonic P2 at 720 x 480 frame size. I’m working in a 720 X 480 sequence in FCP….here’s the problem…I’m experiencing ‘flutter’ on dissolves and ‘stutter’ on moves when I output to video. The default output for Cinewave is 720 x 486….could this be the problem, and is there a way to change the output frame rate on my Cinewave to match the 720 x 480 rate that I’m capturing and cutting in?
    Adam Schmidt replied 21 years, 5 months ago 2 Members · 1 Reply
  • Adam Schmidt
    April 23, 2005 at 5:05 am
    Looks like your fields are backwards. Try changing the sequence settings.
    Adam
