Activity Forums Avid Media Composer How do i change audio levels for multiple clips all at once?
  • How do i change audio levels for multiple clips all at once?
    Posted by Chris Collins on June 16, 2005 at 6:22 pm
    Can i select multiple audio clips together, and change the audio levels of all of them?
    i.e. if clip 1 is at +2, clip 2 is at +4, and clip 3 is at +1, can i change them all by +4 db if i want (making clip 1 +6, clip 2 would be +8, and clip 3 would be +5)? Or,,,can i make them all universally one level of +2 ?
    thanks.
    Chris
    Bob Sykes replied 21 years, 3 months ago 3 Members · 2 Replies
  • Monte Matt
    June 16, 2005 at 7:57 pm
    I’m sure it’s somewhere in the manual or Help. Don’t be so lazy.
  • Bob Sykes
    June 16, 2005 at 11:16 pm
    Mark the clip in to out
    In the audio mix tool :
    1. Activate the tracks you want to adjust
    2. On the Hambuirger Menu drop down to “adjust pans and volume”
    3. You can ajust upward +6db
