Activity Forums Adobe Premiere Pro How do I capture in the background with Premiere
  • How do I capture in the background with Premiere
    Posted by Chris S on May 11, 2005 at 12:43 am
    I would like to work with other programs as premiere captures footage from the miniDV tape. But after I start the capture process and switch to another window in WinXP, the capture stops and asks me to name the newly captured footage.
    How do I capture in the background as I work on other stuff on the computer? I did it before by mistake and dont know how to do it again. Thanks for the help.
    Chris
    Chris S replied 21 years, 3 months ago 3 Members · 6 Replies
  • Aanarav Sareen
    May 11, 2005 at 1:20 am
    What version of Premiere Pro are you using? Background capturing is only supported in Premiere Pro 1.5.
  • Chris S
    May 11, 2005 at 3:17 am
    I am using Premiere Pro v7.0
  • Aanarav Sareen
    May 11, 2005 at 4:21 am
    Premiere Pro 7.0 (1.0) does not support background capturing.
  • Chris S
    May 11, 2005 at 5:46 am
  • Tore Gresdal
    May 11, 2005 at 9:28 am
    Just a quick tip: Scenalyzer is a small shareware program designed for scanning and indexing tapes, and it can do background capture as well. It has a buffer and is surprisingly robust when it comes to interruptions in the dataflow.
    I also find it brilliant for capturing stills from you footage instead of the tedious process of selecting “File -> export -> export to frame -> type filename -> press save”. In scenalyzer you just press F2. Scenalyzer then exports that frame with names with auto increments. (file format, naming, etc are set in the preferences)
    link: https://www.scenalyzer.com
    Regards
    Tore Gresdal
  • Chris S
    May 11, 2005 at 3:50 pm
    Thanks a lot!
