Activity Forums Apple Final Cut Pro Legacy How do I capture analog audio into FCP?
  • How do I capture analog audio into FCP?
    Posted by Chris Foogs on September 25, 2007 at 9:24 am
    I’m trying to capture analog audio from a minidisc deck, through a KonaLS card and into FCP. I have so far managed to be able to hear the music coming into FCP and it can record in voiceover but it is currently only a mono track and limited in length. Is there a way I can use the log and capture tool to only capture audio?
    I have unticked “video” in the clip settings and set the device control to “non controllable device” and the preview window says “video disabled audio capture only”. But when I hit capture now, an error comes up telling me it can’t capture as there is no video?
    Can anyone tell me what I need to do?
    Many thanks, chris. (Running FCP 5.1.4 on a G5 with external konaLS)
    John Fishback
    replied 18 years, 12 months ago
    4 Members · 5 Replies
  • Walter Biscardi
    September 25, 2007 at 12:22 pm
    Set your Device Control to “Non-Controllable Device.” This is covered very well in the Help Menu.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Chris Foogs
    September 26, 2007 at 9:47 am
    Hi Walter,
    thanks for the response, but as I wrote in the original post, I have already checked that setting:
    “I have unticked “video” in the clip settings and set the device control to “non controllable device””
    Have you any other thoughts? I thought I had read somewhere that the system needs some sort of analog video coming in as well to make the analog audio capture work…?
    Thanks for the replies.
  • Walter Biscardi
    September 26, 2007 at 10:04 am
    [Flashish] “I thought I had read somewhere that the system needs some sort of analog video coming in as well to make the analog audio capture work…?”
    Not in my experience. I’ve captured from audio cassette machines with no video hookup at all in the past. Really don’t have any other suggestions for you, sorry.
  • Ronnyahmad
    September 27, 2007 at 3:06 am
    maybe this oldway can help :
    try to digitize your audio bypass using minidv player, connect your output minidisk to input audio in minidv than in fcp set your device to “non-controllable device”, just in case set your capture/input to dv pal
    regards,
    ronny
    Brunei
  • John Fishback
    September 29, 2007 at 11:51 pm
    Do you have ref video going to your Kona? FCP may want a video source for timing even though it’s only recording audio. Try sending some video to the card while you try to record the audio and see what happens.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.2, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
