Activity › Forums › Adobe After Effects › How do I blur the edges of the alpha?
Posted by Kevin Camin on April 25, 2012 at 8:53 pmI have some keyed out footage, but it looks a little too crisp around the edges. I want to just slightly blur the edge a pixel or two. I’ve tried Channel Blur, but it leaves a hard outline.
Thanks.
Best regards,
Kevin Camin
Marc Nibor replied 10 years, 6 months ago 6 Members · 6 Replies -
Tudor “ted” jelescu
April 25, 2012 at 9:13 pmYou can try Matte Chocker- it takes a bit of tweaking but the results are pretty good.
Tudor “Ted” Jelescu
Senior VFX Artist -
Andrew Somers
April 25, 2012 at 9:51 pmHere is yet another method:
Apply a BLUR to the ALPHA, and after the blur, add a LEVELS effect.
Adjust the blur to your liking, then adjust the GAMMA on the levels effect to choke the blur into your edge.
John Cuevas
April 26, 2012 at 12:07 amChannel blur allows you to directly blur an alpha.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Chris Buttacoli
April 26, 2012 at 8:32 pmHey, Ted – is that related to matte-chocker-full-of-nuts coffee?? 🙂
How about using the keyed footage as a track matte layer and just bluring that with fast blur. It will need to be pre-composed first, I believe.
Kevin Camin
April 26, 2012 at 9:48 pmThanks everyone for the great suggestions!
And, yes, I got the Channel Blur to work, but it’s not a straight forward process. If you blur just the alpha channel, but the R,G, & B channels are not blurred, it won’t create a soft edge because RGB channels are still “hard”. But if you blur all color channels and alpha, it works, but the entire image is blurry at that point and you’ll need to dup the layer and do a matte choker or some other technique on a top layer.
Best regards,
Kevin Camin
Marc Nibor
February 14, 2016 at 4:44 pmThanks Ted!
already 4 years old – but exactly what I needed right now ; )
