Activity Forums Apple Final Cut Pro Legacy How do I best convert clips in Compressor?
  • How do I best convert clips in Compressor?
    Posted by Noam Osband on March 13, 2016 at 2:45 pm
    1 – I have footage in Compressor. I’m convert 30 fps to 24 fps. I custom set frame speed to 23.976 in Pro Res. Any other advice on settings?
    2 – I’m using Compressor to do this. Would Cinema Tools be better? Or MPeg Streamclip or Handbrake perhaps? Just wanna get the best image possible.
    John Pale replied 10 years, 5 months ago 3 Members · 6 Replies
  • Shane Ross
    March 13, 2016 at 5:44 pm
    IN the FRAME CONTROLS section of the Inspector in Compressor, set all the settings to BEST.
    Shane
    Little Frog Post
  • Noam Osband
    March 13, 2016 at 9:24 pm
    If a clip is 59.98 and i’m using it in a 24 fps sequence, it would behoove me to convert it the same way I am converting the 30 fps clips, correct?
  • Shane Ross
    March 13, 2016 at 10:15 pm
    Yes
    Shane
    Little Frog Post
  • Noam Osband
    March 14, 2016 at 3:33 am
    it’s 23.98. I’m in the middle of converting the hundreds of gigs I edited with from 24 to 23.98. I’ll take one ciip and (re)connect it to the new version, and assuming everything looks ok, reconnect all the others.
  • John Pale
    March 14, 2016 at 5:35 pm
    Ignore post
  • John Pale
    March 14, 2016 at 5:43 pm
    FYI….Converting 24 to 23.98 is an entirely different operation, best done in Cinema Tools (but can be done in Compressor). For this you want to do a conform (which is instantaneous and has zero quality loss). Doing a regular transcode will introduce frame blending.
